1972 corvett brakes - NCRS Discussion Boards
1972 corvett brakes
  • bill mancuso
    1972 corvett brakes
    i have a 1972 big block coupe the car has had brake problems for a long time . i have replaced every part of the brake system . new rotors .002 runout calipers pads several types master cylinder hoses lines . it does not have power brakes. it has a firm petal and will not stop the car with all the pressure that i can apply the proportional valve has not been looked at does any body have any ideas thanks
    • 15601
    Re: 1972 corvett brakes
    What is the casting number on the master cylinder? If it is a Delco master cylinder the casting number will be on the inbord side -- facing the enine.
      • 43221
      bill-----
      I suspect a possible master cylinder problem, too.
      The "proportional valve" is NOT a proportioning valve, at all. Its functions are only pressure differential sensing and fluid distribution.
      One thing I would suggest is obtaining a brake pressure gauge and checking the actual pressure at each corner when the brakes are applied. You can get these gauges from Stainless Steel Brakes in Clarence, NY.
        • 15601
        The reason I asked about the master cylinder is if a cylinder for power brakes were installed, this would create the symptoms described.
        In the absence of a Delco cylinder and its casting number, measuring the diameter of the master cylinder would tell.
          • 15601
          • bill mancuso
            i have checked the master cylinder bore . i to thought it could be wrong but it is not . i should be able to slide the wheels not even close . seems to be plenty of fluid when i bleed the brakes .
            • bill mancuso
                • 43221
                bill-----
                Even if it's the correct bore size, there could still be a problem with it. At this point, I would say that it's one of 2 things:
                1) the master cylinder is not performing correctly;
                2) there's air still trapped somewhere in the system, probably at the master cylinder. Did you bench bleed the master cylinder prior to installation?
                  • 43221
                  bill-----
                  • bill mancuso
                    i have had three master cylinders on the car all the same symtons . i used my brake bleeding tool to remove the air firm petal
                    • bill mancuso
                      • Dennis H.
                        • August 31, 2005
                        • 53
                        I had the same problem on my 71 manual brake car. After bleeding the brakes several times, I bought a MityVac vacuum pump. After using it, the brakes were perfect. I would have bet 100 bucks that I had it bled properly but there was still air in the system until I used the MityVac.
                        • Dennis H.
                          • August 31, 2005
                          • 53
                          • bill mancuso
                            thanks dennis i have the mity vac and use it good tool . what type pads do you use or suggest . it has been a while sense i put them on i dont remember what i used . i work mostly on early chevrolets on some i have had to change the type of shoes to get them to stop . the vett has a firm petal no stop . thanks
                            • bill mancuso
