Where's RAY? - NCRS Discussion Boards
Where's RAY?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11345
    Re: Hope she whipped your butt...
    ...I thought the Restorer article said it was a '65....must've been a typo. So it's the 3.8L XK engine, yes very responsive. The V12 is a 5.3L, 326ci at about 300hp using 4 Zenith Strombergs. My 59 with the dual Carters is only 270hp by comparison.
    Yep, she did whip my butt, but not off the line. The V12 is sluggish there, but after a short time it is like a rocket. Driving that car on the highway is scarey. At 70mph spinning at about 3500rpm it talks to you. It says, "c'mon, what're you doing, lets go!" It is absolutely amazing. You put your foot into the accelerator at 70mph and the engine is at it's best. Without even downshifting, it is startling. The torque at the high end is incredible. You are propelled forward, shooting ahead like a rocket, watching the rearview mirror objects behind you rapidly dissapear.
    59 keeper & 62 project
    (ps-I'd never own a Jag:-), I'm just the wife's mechanic!)
    • Jim T.
      • March 1, 1993
      • 5351
      How often do you have to replace oil in the V12's 4 carbs?
      • Jim T.
        • March 1, 1993
        • 5351
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11345
          Re: Mr. Lucky 1959
          I refilled a few years ago when I rebuilt them and the engine when I did the restoration. I check it whenever I check other fluids. I usually add a few squirts from the oilcan to keep them topped up if needed. A slight loss through the o-rings, but that's normal. I never change it, just add when needed. The car has just under 100,000 miles on it now and it's never been a problem.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11345
            Re: Mr. Lucky 1959
