C2 body dolly - NCRS Discussion Boards
C2 body dolly
  • Rex T.
    • December 1, 1984
    • 455
    C2 body dolly
    Where can I get some plans for a sturdy body dolly for restoration of a 64 coupe?
    Rex
  • Dale Osterman
    Re: C2 body dolly
    Rex,
    Go to the NCRS Store on this web site and order Noland Adams "The Body Lift Workbook". There is a dollie and bill of materials in the manual. I have also seen them made with steel tubing like a roll cage with body mounting points so the whole body can be rolled. They take more engineering and welding. Hope this helps.
      Re: C2 body dolly
      Rex -
      NuAir makes a nice one from extruded aluminum - when you're done with it, it breaks down for easy storage or you can sell it to someone else looking for a dolly.
      • Stephen L.
        • May 31, 1984
        • 3162
        Re: C2 body dolly
        Make your own dolly. Worked great for me both in the garage and transporting in a trailer. Also CHEAP to build. When you get done with it use it for firewood to heat your house.....
        Plans:
        Finish product:
        • Gary B.
          • February 1, 1997
          • 7055
          Steve; Is that blackout paint on...
          the back and outside of the storage area buckets?
          Gary
          • Stephen L.
            • May 31, 1984
            • 3162
            Re: Steve; Is that blackout paint on...
            The body had not been restored when this photo was taken. The "black" was not correct. The photo depicts the dolly......
            • Gary B.
              • February 1, 1997
              • 7055
              Body color in rear wheel wells
              Steve,
              I asked about the blackout paint since I'm cleaning the underbody of my car during its frame off restoration and when cleaning the rear wheel wells I found what I think is body color (dull red) under all the grime and crud that I removed. So now, I have some bare fiberglass and some body color and I wonder if I should leave it as is or should I used some blackout for cover up the body color and make it look more uniform. To be clear, the body color is on the vertical outer sides of the storage bins.
              Gary
              • Stephen L.
                • May 31, 1984
                • 3162
                Re: Body color in rear wheel wells
                If you think its the original paint then leave it. The Blackout came last so the blackout painter didn't cover that area....and the body color guy just got a little to aggressive.... None of this was "science" especially when the painter probably painted one every 5 minutes....
                • Stephen L.
                  • May 31, 1984
                  • 3162
