Oil pressure - NCRS Discussion Boards
Oil pressure
  • Paul K.
    • February 1, 2002
    • 160
    Oil pressure
    I have a 66 327/350. will switching to 15w40 diesel oil raise the oil pressure, and if so, does that hurt the engine.
    Paul Klemetson
    • 43259
    Re: Oil pressure
    Paul-----
    Assuming that you're using something like 10W-30 now, I doubt that you'll notice any significant increase in pressure with the 15W-40. You might notice that it runs SLIGHTLY higher pressure when the engine's at operating temperature and at cruise RPM. The 15W-40 will absolutely not hurt anything.
    • Dick W.
      • 10483
      Re: Oil pressure
      Paul, the 15W-40 oil may raise your oil pressure slightly, depending on the condition of your engine. The pressure difference will not affect your engine.
      Dick Whittington
      • Paul L.
        • November 1, 2002
        • 1414
        Re: Oil pressure
        Another option is to use diesel 10W-30 if the heavier weight oil concerns you.
        • Paul L.
          • November 1, 2002
          • 1414
          Re: Oil pressure
          OK, no replies. I use this CH-4/SH oil in my 1967. Available at Canadian Tire in Canada. About $3.00/liter.
          • Paul K.
            • February 1, 2002
            • 160
            Re: Oil pressure
            Thanks for all your advice.
            Paul
