1962 Tach Cable - NCRS Discussion Boards
1962 Tach Cable
  • Jeff C.
    • September 30, 1997
    • 233
    1962 Tach Cable
    What is the correct length tach cable for a non FI car? I have seen both 32" and 36".
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11322
    Re: 1962 Tach Cable
    Jeff, I have an original 250hp car and will check for you today. It has it's original gray covered cable, disconnected from it's replaced non tach drive distributor.
    Rich Mozzetta
    • Alan Drake
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11322
        Re: 1962 Tach Cable
        Jeff, Just removed the tach cable from the car(early 62 #483 Sep,61 build). On the bench, I accurately measured end to end of the gray outer casing housing flanges, it is 36" long. The inner drive cable is 37 1/8" long, I imagine as Alan shows as the "62 1st design 5656347 37 1/8 65 Parts Book"
        Hope it Helps,
        Rich Mozzetta #13499
