The FIRST 6.0L Chevrolet Engine - NCRS Discussion Boards
    • 43221
    As most of you know, GM has used a 6.0L engine in many recent applications. These include C5 and C6 Corvettes, many trucks, Pontiac GTO, the new Pontiac G8, and others. This is the NEW 6.0L engine. It's, of course, built on the Gen III small block architecture. The bore and stroke configuration of this engine is 4.00" X 3.62" and it displaces 364 cubic inches.
    However, it's not the first 6.0L engine GM has produced. The first was introduced way back in the later 60's and it was based on the Mark IV big block architecture. It was never installed in any passenger car, though; it was strictly a truck engine, although it was used in light duty, medium duty and heavy duty models. It displaced 366 cubic inches. It didn't have a bore and stroke configuration like the modern-day engine, though. It had a bore of 3.938" (just 1/8" larger than a 283) and a stroke of 3.76" (same as 396 and 427). So, unbeknown to many, there was once-upon-a-time a big block with a bore size smaller than 4".
    The 366 lived for quite awhile, although I don't know just when it was officially discontinued from manufacture. I do know, though, that it did not survive into the Gen V period which began in 1991. Also, by the early 1970's, I believe the 350 cid small block displaced the 366 for most light truck applications and the 366 became more-or-less only used for MD and HD trucks.
  • GL Anderson
    Re: The FIRST 6.0L Chevrolet Engine
    IIRC the 366 was not used in a light duty truck that is a series 3 and below but only on 4 series and up which at the time were Medium Duty trucks. We sold a ton of them to farmers because the torque was great. The light duties still used a 396/402 and later 454 engine. Also the block was taller in the 366 plus it was made as a 427 also, the racers sometimes bought the blocks for long stroke applications. GL
    • Mark #28455
      Great for supercharging
      You can take a 366 truck engine add the later open chamber 454 heads and flat top pistons and supercharge the heck out of it because it has a strong bottom end. Works GREAT in boats where you need steady high power output. Gale banks sold more than a few 372's with twin turbos making over 700 HP to the boat crowd.
      Mark
      • Tom H.
        • December 1, 1993
        • 3440
        Re: Great for supercharging
        Isn't the deck surface visibly higher on the 366 engine ?? Seems to me you could always spot them by the area where the water pump bolts on. Had a little more meat in the truck block.
        I remember when we used to stock these in dump trucks and flat beds in the truck department.
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
        • Clem Z.
          • January 1, 2006
          • 9427
          the block was taller by .400
          this was because the pistons used 4 rings instead of the normal 3 so the piston was taller. .
