1965 FI Rear End - NCRS Discussion Boards
1965 FI Rear End
  • Richard J.
    • August 31, 2005
    • 83
    1965 FI Rear End
    Hello all... I am in search of a bit of technical information about a 1965 FI coupe with F-40 suspension. It was built in March of 1965. According to the original window sticker it states an FA rear end code. My question is... Would a small block FI car have the steel straps holding the half-shafts to the stub axles or would it be like the big block with cast iron caps? Any help is greatly appreciated. Rick
    Rick Jones
    Albuquerque, NM
    Member #44319
    • 43221
    Re: 1965 FI Rear End
    Rick-----
    For the most part, small block equipped Corvettes built through about 1969 used the u-bolt-type stub axles. Beginning in 1970, some small blocks did receive the HD, cap-type axles.
    However, if the car you mentioned was originally equipped with an "FA" coded differential, then it should have the cap-type axles. The "FA" code was primarily used for big blocks with 3.70:1 posi and the "AO" code for small blocks with 3.70:1 posi. In fact, the only difference between the "FA" and "AO" coded units is the axle type.
    • Wayne M.
      • March 1, 1980
      • 6414
      Don't confuse ECL codes with stamped codes
      Your window sticker probably shows "02G81FA", which means small block 3.70 ratio posi.
      By pure coincidence, the '65-67 STAMPED code on the differential carrier bottom flange is "FA" for big block 3.70 ratios, and therein the confusion lies.
      The original small block 3.70 stamping will be "AO"
