54 corvette heater defroster switch - NCRS Discussion Boards
  • Brad H.
    • August 12, 2007
    • 724
    Did they make repros that were identicle and do they still make them if one cant find an original working unit? Brad
  • Mike M.
    • May 31, 1974
    • 8385
    Re: 54 corvette heater defroster switch
    not aware of repos(demand wouldn't yield profits to a repo company). i've disassembled non-operative switches and got them working. suspect you'll have to find an original. good luck, mike
    • Brett H.
      • January 1, 1996
      • 367
      Corvette Specialties of Maryland has them. They are on ebay quite often, new repro for about $150.00
      Hope this helps
      • Brad H.
        • August 12, 2007
        • 724
        Brett, will they judge out as original? thanks again Brad
        • Brett H.
          • January 1, 1996
          • 367
          I feel that they will. They look and operate the same. They do not weight the same due to the casing on the switch being plastic rather than bake-lite. I haven't had one judged NCRS but I have at Bloomington and did not recieve a deduction for 1953 #130 last June. It got Gold.
          It is judged in the operations section. The new switch is probably safer than an old switch with a brittle ceramic coating over the coil.
          Does anyone know where an original switch can be rebuilt? I have several that I would like to rebuild, if possible.
          Maybe an NCRS judge can tell us their experiences with this switch??
          Brett
