69 headlight bezel - NCRS Discussion Boards
69 headlight bezel
  • Frank Bernier
    69 headlight bezel
    Hi Guys
    my 69 vette as plastic headlight bezel .. i know its not correct ... and i bought 2 diecast bezel ... but without washer holes ... can any one tell me if that can be noticed by any one if the holes are drilled at the exact same spot... as original
    also can anyone be nice enough to send me detailed pics of the position of both washer nozzole for both bezel
    thanks alot Frank
  • Richard F.
    • May 31, 1986
    • 193
    Re: 69 headlight bezel
    It sounds like you have 68 bezels, which are far more rare, and probably more valuable than 69's. Rather than ruin their originally, maybe you could Ebay them, and wait for correct 69's.
      • 43260
      Frank and Richard-----
      They're either the 1968 bezels or the 1972 bezels----both were the same.
      The holes for the washer nozzles are not round; they are "D" shaped in order to index the nozzles to the "correct" position. I don't know how you would be able to re-create these precisely. I suppose they could be drilled round, the nozzles positioned properly and the flange nuts tightened. No one would be the wiser that the holes weren't of the proper configuration.
      • Richard F.
        • May 31, 1986
        • 193
        Joe, I just went back into the archives (around year 2000), and was fascinated to read your various treatises on this subject. I always wondered about this history. My 1976 parts book only lists the later plastic ones. I am enlightened.
        • Harmon C.
          • August 31, 1994
          • 3228
          The metal headlight bezel were also used on early 73's. The change to fiberglass happened in about December 1972.
          Lyle
          Lyle
          • Dennis D.
            • March 1, 2000
            • 1071
            Not sure if the archives took you back to my inquiry years ago. However there were 2 locations on the placement of the D shaped holes.
            To sum it up, I think the general concensus was the bezel with the holes on the horizontal surfaces,(top and bottom), was the first design, being they are so difficult to remove. The 2nd design placed the lower hole on the vertical surface between the lights. Makes it much easier to remove. Hence the second and improved design for a rather silly system.
            Not sure if NCRS has determined officially when a cut off as to use would have been. Just to add to the confusion
