Coupe trim - NCRS Discussion Boards
Coupe trim
  • John M.
    • January 1, 1999
    • 1553
    Coupe trim
    I have been looking for a small piece of trim for a 64-67 coupe and have had no luck finding one. I am hoping that someone can steer me to a vendor that might have a used one, as this part is not being reproduced. I need the little pie-shaped piece of stainless that goes on the inside of the drivers window at the rear, and fills the corner. I believe that the original GM part # was 3840585. Any leads would be appreciated.
    Regards, John McGraw
  • Charles F.
    • April 30, 2006
    • 99
    Re: Coupe trim
    John:
    I just did a search in e-Bay (nothing) and Google for the part number you list. In Google Pacific Corvette came up with the part number, described as follows for $100: 63-67 SEAL ASSY LH LWR INR CORN CPE. The web address is:
    www.pacvette.com. I don't know if this is what you want nor do I know anything about the vendor. Hope this helps.
    Chuck
      • 43221
      Re: Coupe trim
      Chuck and John -----
      Pacific Corvette in Puyallup, WA is an excellent source for used Corvette parts. They are, basically, an auto dismantler but "they do things a little differently". What they do is to dismantle Corvettes right down to every usable piece AND INVENTORY THE PARTS BY THE ORIGINAL PART NUMBER SHOWN IN THE AIM. This makes identifying the piece so much easier. You just call them with a part number (from your AIM) and they can look it up in their system just like a GM dealer in "days-of-old" would have looked it up. The difference being that the part, if they have it, will be used and not new. They do have some NOS stuff, too, but their "main thing" is used parts.
      • Gary B.
        • February 1, 1997
        • 7023
        Pacific Corvette
        All,
        My experience with Pacific Corvette is that sometimes I searched for a part number on teh web (via PartsVoice, I recall) and it will indicate that Pacific Corvette has it, but it will turn out that they have a repro part that they list in the system under the GM part. I think I did this with tie rod ends (I think) and when I called them they said they only had repro. So, just bacause it looks like on the web that they have a part, it doesn't mean that it's a real GM part.
        Gary
          • 43221
          Re: Pacific Corvette
          Gary-----
          Yes, that does happen with them. Also, they sometimes do not actually have the used part that their "inventory" says they have. But, if one is looking for a rather rare and hard-to-find item, they are a good "first call". The main advantage is that they use part numbers instead of just descriptions.
          Also, the problem with inventorying and listing parts by GM part number which are actually reproduction or, even, just replacement parts is not unique to Pacific Corvette. Many vendors do this. For example, Modern Chevrolet on the east coast seems to do this quite often.
          • John M.
            • January 1, 1999
            • 1553
            Thanks guys, but they did not have one. I called them and they had the RH one but not the LH. I have tried all the major players that I can think of.
              • 43221
              John-----
              Well, there's always the J. T. Piper's Corvette Specialties of Vermillion, IL. There's a good chance they have it, either used or NOS. There's very little chance that you'll like the price, but, if all else fails........
                I got a handful of them in the early 70's from the original production supplier (USM - United Shoe Machinery Co.), which they said was the last of their Engineering samples, and used them since in several restorations. Haven't seen another one since.
                • Tracy C.
                  • July 31, 2003
                  • 2739
                  Re: Coupe trim
                  John,
                  Sounds like you may need to dust off the ole aircraft sheetmetal tools and fabricate one yourself John.
                  If you can find a scrap piece of something even remotely close, my guess is your homemade repop piece will look OEM when you get finished with it.
                  good luck,
                  tc
                  • Mike M.
                    • May 31, 1974
                    • 8385
                    10/4 on disliking JT's pricing methods. mike
                    • John M.
                      • January 1, 1999
                      • 1553
                      Re: Coupe trim
                      Tracy,
                      I was thinking that same thing this afternoon! There is so little of it showing when the door panel is on, that I am sure that a polished piece of aluminum would probably work.
