Off road exhaust - NCRS Discussion Boards
Off road exhaust
  • Dave C.
    • March 1, 2004
    • 82
    Off road exhaust
    Dumb question but what is "Off road exhaust System" optino N11????
  • James W.
    • December 1, 1990
    • 2669
    Re: Off road exhaust
    Yep, that's it. Less baffles in the mufflers means less restriction and more noise, they sound great on a high winding small block.
    James West
    • Wayne K.
      • December 1, 1999
      • 1030
      Under car exhaust with low restriction mufflers. *NM*
      • Bruce B.
        • May 31, 1996
        • 2930
        These are the round mufflers (roughly 4" TO 5" diameter) which flow exhaust better then the conventional oval shape Corvette mufflers. They sound good but not overly loud or obnoxious.
        • Alan Drake
          Re: Off road exhaust shape
          For at least the 64 model year these are oval shaped. I have never seen a round one at least on a 64, however others may know different for different years. Note, have a set on my car (service) and another car nearby also has same, but original still and has a service set at his shop.
          • Dick W.
            • 10483
            Me thinks that the round mufflers are C-1's and the N-11 was a C-2 option. Both were called "off road" but only the midyears had a option code
            Dick Whittington
            • Mike G.
              • July 31, 2002
              • 709
              i wish it was an option for the 70. it sounds good on my 57
              • Jim W.
                • February 1, 1980
                • 324
                '67's are oval also and one-piece.
                  • 43259
                  Jim------
                  ALL 1963-72 Corvette mufflers (except side exhaust, of course) are oval in configuration and, except for inlet pipe size and hanger brackets, are all the same in external configuration.
                  1973-82 use a "semi-circular" configuration muffler.
                    On C1's they were round straight-through mufflers; on midyears, they were externally identical to the oval production mufflers, and had less internal baffles.
