Wiring harness clip bond - NCRS Discussion Boards
  • Albert P.
    • April 1, 2006
    • 205
    AIM for 1964 shows clip on driver side fender for headlight harness as being bonded to skirt;what should be used to bond this clip to the skirt?Thanks.
  • Albert P.
    • April 1, 2006
    • 205
    Re: Wiring harness clip bond
    Correction, this clip holds the headlight and alternator harness;thanks.
    • John O.
      • May 31, 1998
      • 480
      Hi Garth
      On my 62, I used JB weld to hold my clips for my headlight harness. Worked great.
      Good luck...John
      • Wayne W.
        • April 30, 1982
        • 3605
        The factory used the same material as used on the body. Polyester puddy.
        • Albert P.
          • April 1, 2006
          • 205
          **NM Thanks for info onWiring harness clip bond *NM*
