distributor lubrication - NCRS Discussion Boards
  • R N.
    • May 31, 2002
    • 640
    Hello All,
    What grease/lube should be used for the lube pads under the centrifugal advance weights?
    Thank you in advance.
    Kurt N.
    • 15706
    Re: distributor lubrication
    I don't recommend any kind of grease. It will just get gummy and attract dirt.
    Clean everything thoroughly and wipe down the parts with WD-40, which will inhibit surface corrosion and provide all the lubrication that is necessary.
    Nothing in the autocam assembly is heavily loaded, so no specific lubrication is required.
    • Gerard F.
      • June 30, 2004
      • 3806
      Kurt,
      I used Tri-Flow instead of WD40 per Duke's recommendations on my 67 distributor.
      Basically the same stuff but Tri-flow has a little teflon in it.
      Soaked the old lubrication wick with it, then squeezed it out and let it dry. Found that you can't find those wicks anymore. I guess they don't put them on replacements.
      Here's the top of my 67 base engine distributor refurbed, with the original weights and springs:
      Runs like a top.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
        Jerry -
        Paragon has the "wick" and plastic retainer - their #12650.
