door window regulator - NCRS Discussion Boards
  • Martin Pfaendler
    I am rebuilding my 1962 side door window regulators. For each a circular spring puts tension on the regulator. When I took the spring I forgot to note in what direction the tension is. Does the spring help to raise the window or to lower it?
    Any help is appreciated. Martin Pfaendler
  • John M.
    • January 1, 1999
    • 1553
    Re: door window regulator
    The spring helps raise the window. It overcomes the weight of the window glass.
    Regards, John McGraw
