C3 - Trans Number - NCRS Discussion Boards
C3 - Trans Number
  • Greg F.
    • February 21, 2007
    • 253
    C3 - Trans Number
    Can anyone tell me the 7 digit GM ID number for a 71 350/270 transmission, please. Greatly appreciated and thanks!
  • Jim T.
    • March 1, 1993
    • 5351
    Re: C3 - Trans Number
    Starts with a P that represents Muncie. If it has the suffix letter A in the sequence it identifies the M20 wide ratio, suffix letter B is the M21 close ratio, and suffix letter C is the M22 close ratio "rock crusher".
    • Warren F.
      • December 1, 1987
      • 1516
      Greg,
      There are actually 3 different casting numbers used on the Muncie manual transmissions. Since you own a '71 ZQ3 car I going to assume you have a M20 wide ratio 4spd transmission. The numbers you are looking for are maincase 3925661, extension housing 3978764, & sidecover 3952648.
      To identify if this transmission was assembled for use in a 1971 model Corvette, you need to decipher the assembly stamping. An example for '71 model year would look something like this... P10321A
      • Greg F.
        • February 21, 2007
        • 253
        Re: C3 - Trans Number-Thanks, that's what I needed *NM*
