Hello All! - NCRS Discussion Boards
Hello All!
    • 11622
    Hello All!
    HI!
    Welcome to the new, improved version of the NCRS Discussion Board. It's good to have it back!
    See you around!
    Patrick Hulst
  • Juliet P.
    • June 30, 1999
    • 349
    Re: Hello All!
    Very glad to have the old format back! Thanks John. Patrick, how'd ya beat me over here? ~Juliet
    Click for the 1970 Corvette Registry
    2019 Sebring Orange 8-Spd Coupe (daily driver & autocross) 6k mi.
    1970 Bridgehampton Blue Convertible - Chapter Top Flight 2005 68k mi.
    1965 Coupe (Greg's project No Flight)
    Gone but not forgotten:
    1987 Yellow Convertible 199k mi.
    2002 Yellow Convertible 100k mi.
    2007 Atomic Orange Coupe 140k mi. RIP flood 2015
    2007 Lemans Blue 6-Spd Coupe 34k mi.
      • 11622
      Re: Hello All!
      Juliet,
      My rebuilt and mildly modified 270hp 1971 is faster than your old stock 300hp 1970.
      Good to meet you at Carlisle (in person). And by the way, you car doesn't look as bad as you think it does.
      Patrick
      My 1971 Corvette
      • Juliet P.
        • June 30, 1999
        • 349
        Re: Hello All!
        Must be the extra drag of having the top down I guess. ~Juliet
        • Don E.
          • September 30, 1991
          • 9
          Re: Hello All!
          Hello to all. Good to be back
          • Roberto L.
            • January 1, 1998
            • 523
            Re: Hello All!
            Hello, finally!!! Glad to be back here. Let's talk about Corvettes! Roberto, NCRS #30019, RMC
            • Don O'Connell #33101
              Re: Hello All!
              John,
              Thanks a bunch!
              Don
              • Steve Epps
                Re: Hello All!
                Hello all! and Thanks to John and all those involved in the site.
                -Steve
                • Phil Fischer
                  Re: 62 Corvette Strg Column Tube
                  I just removed the steering box assembly from my 61', and took the steering column tube apart from the steering box....All I did was use a small hammer, and using the square opening where the turn signal wires exit the tube, I tapped against the tube housing, and that easily drove it out of the steering box. I am currently having the correct red color mixed to repaint the tube prior to re-assembly...... I hope this helps you......Phil
                  • Tom Merkel
                    Re: Clockworks contact info
                    Ed- It's pretty clear you were satisfied with Clock Works. I think I'll pull mine and send for install of NOS mechanism.
                    Now, how do you recommend getting the sucka out?
                    Thanks.
                    Tom
                    • Ed Jennings
                      Tom, it SHOULD be pretty simple. Depress the clock at the face and twist counterclockwise (as viewed facing the clock). It should twist about 1/8 turn or so, and come out toward the interior or rear of the car. Now, if the clock hasn't been out in a while you may have a bit of corrosion to deal with. You may have to reach in from the back side to get a firm grip on it to turn it. Be sure that the whole clock is depressed about 1/8-3/16" and is depressed evenly. Once you get it out, you can see that it is a pretty simple thing. The wavy spring is what holds it in place by putting forward pressure on the case. When reinstalling, I strongly recommend putting a 1 amp fuse in line with the power supply wire.
                      • Tom Merkel
                        Thanks, Ed. I forgot to add it's a '67 conv. Assume the procedure is same. Good thought about 1A fuse.
                        And it's never been out of car. So, I'll hope for the best re: corrosion.
                        Tom
                        • Wayne M.
                          • March 1, 1980
                          • 6414
                          Surge Tank Dates - any months skipped ?
                          Did Harrison batch-produce these items, and if so, were not all month codes used ? If so, would Dewitt know which and stamp accordingly ?
                          • Ed Jennings
                            Whooooa!!!
                            Everything I described is regarding removal of a clock from a 58-62. To remove the clock from a C2, remove the radio side panels. There is a clip on each side of the clock that can be removed by depressing the piece that sticks out toward the engine and then sliding the clip to the outside. DO NOT DEPRESS the clock from the paassenger compartment. Same advice regarding the 1 amp fuse applies. If you are not interested in originality, there are quartz conversions for these clocks that are simple enough to be installed by the average owner. Clockworks will repair your original movement cheaper than the quartz conversion, however.
                            • Mike G.
                              • April 30, 2001
                              • 180
                              Thanks Bill! *NM*
