68 Brake Wiring - NCRS Discussion Boards
68 Brake Wiring
  • Jerry G.
    • February 1, 1989
    • 226
    68 Brake Wiring
    I have a brake light problem. Headlights, side markers and tail lights work when headlights are on. My problem is with the right rear not working when flashers, turn signals and brakes are on. I just replaced the turn signal switch in the column, which somebody had cut and spliced. No brake lights at all before I replaced it. The left side works now. It has Heavy Duty flashers. I ran a new ground to the right rear, but no help. Any help would be GREATLY appreciated.
  • Dave P.
    • June 30, 1991
    • 192
    Re: 68 Brake Wiring
    • Jerry G.
      • February 1, 1989
      • 226
      Re: 68 Brake Wiring
      Thanks Dave, I'll check those out. It could be some corrsion at the sockets, since I ran another ground. Since the left side works, I guess it could be either the green wire between the left and right side lights is bad or the ground on the housings. I would think it would have to one of the two. I'll let you know what happens. Thanks again.
      • Dave P.
        • June 30, 1991
        • 192
        Re: 68 Brake Wiring
