Delco Dist Cap - NCRS Discussion Boards
Delco Dist Cap
  • Bill Purdy
    Delco Dist Cap
    Hi, I picked up a Delco Remy dist cap at a swap meet , can anyone help identify its use. It is brown bakelite with copper terminals . On top it says Delco-Remy and Patent 571534.
    Regards Bill
  • Lyndon S.
    • April 30, 1988
    • 1027
    Re: Delco Dist Cap
    was that used on a L88 or did they also use a black one also?
    • Dave S.
      • August 31, 1992
      • 2927
      Re: Delco Dist Cap
      Bill,
      If memory serves me right I think you have a cap that is either Oldsmobile and/or Pontiac. I do think it fits a high performance car and has some collector car value. The 571534 window "index" I believe is different that a D-308. Also, I think those 571534 caps are much heavier plastic that the normal D-308 Delco caps used on Chevrolets for some unknown reason. Joe Lucia should be able to help here.
      • Dick W.
        • 10483
        Re: Delco Dist Cap
        L/88's used the brown cap. International trucks of the mid and late '60's also used a brown cap but I do not remember the window index.
        Dick Whittington
        • Mike M.
          • May 31, 1974
          • 8403
          Re: Delco Dist Cap
          dickie: thought brown cap on l-88 had been disproven. then again, i'm no c-3 guy and never seen an original unmolested 67 L-88. mike
          • Dick W.
            • 10483
            Re: Delco Dist Cap
            Who had Doc?? I have seen a few under 5,000 miles with the brown cap but no way to verify if it is original.
            Dick Whittington
              • 43260
              Re: Delco Dist Cap
              Bill-----
              I think that what you have here is a D-325, aka GM #800063. This was used on some 60's Cadillac applications. However, to be sure, compare it to a known Delco D-308 (still available from GM or Delco). If the window is in exactly the same place as the D-308, then what you have is a D-309. If it's in a different relative location, then you have the D-325.
                • 15706
                Re: Delco Dist Cap
                I ran the TI system from the "12-mile" '67 L-88 on my SWC for several years. When I sold it to David Burroughs circa 1987 to install on the original car from where it came, it still had the original brown distributor cap. I also reinstalled the VAC with the cut off nipple and the original weights and springs, which I kept in a box over the years as I ran a Delco ...236 VAC and '64-'65 SHP/FI weights and springs.
                I saw that L-88 the day it arrived on a flatbed from Alan Green Chevrolet. Then I helped the original owner molest is big time!
                • Bill Purdy
                  Re: Delco Dist Cap
                  Thanks Everyone, I should have given you this info in the origonal post. The Delco Service Part box has on it , cap 800061 and #D309R . Sorry I left that info out.
                  Regards Bill
