C3 carpet question - NCRS Discussion Boards
C3 carpet question
  • Jeffrey S.
    • May 31, 1988
    • 1882
    C3 carpet question
    Hello all. Is there any difference between an automatic transmission and manual in the passsenger side carpet on a '69? I cannot get the carpet to lay properly on the vertical surface near the floor below small the console access piece. I have an original floor mat and it is marked "cut here for automatic transmission" which leads me to believe that there may be a difference. Thanks for you help.
    Jeff
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: C3 carpet question
    Jeff
    Yes their is a difference but the vendors only sell one type and I think it fits automatics. Al Knock told me a long time ago if I special ordered carpet he had the mold and could make carpet to fit a four speed. In a four speed you have a spot as you describe that won't lay properly.
    Lyle
    Lyle
    • Jeffrey S.
      • May 31, 1988
      • 1882
      Lyle:
      Thanks for the quick response. The fact is I have an automatic and thought perhaps they only sold carpet cut for a manual. Could you have it backwards?
      Jeff
      • Harmon C.
        • August 31, 1994
        • 3228
        Jeff
        I could have it backwards as it's been long enough ago I'm not sure on this one. Must have been ten years ago.
        Lyle
        Lyle
          • 11640
          Jeff,
          Lyle is correct. You usually get the automatic carpet unless you specify as he noted. The automatic carpet doesn't fit well in a 4 speed car.
          Patrick
