After a year-long project I finally got the ole-L75 fired up after a complete rebuild. After a little rework on chasing leaks and resetting the distributer I got around to mapping the advance curve.
I took JohnH approach and set initial @ 6 with the weights banded. Then connected the vacuum advance control and popped up to the expected 22 degrees advance. Then went on with the mechanical weights freed-up to map the mechanical advance curve.
It appears the mechanical advance comes in early and finishes short of spec. Here are my results
RPM TotalAdv Mech(tot-22) Spec diff
600 29 7 0 +7
1500 40 18 15 +3
2000 43 21 -- --
2500 43 21 -- --
4100 44 21 26 -5
How can I teak the springs and stop to achieve the spec and ultimately best performance. BTW...my idle vac is around 18 inches.
600 29 7 0 +7
1500 40 18 15 +3
2000 43 21 -- --
2500 43 21 -- --
4100 44 21 26 -5
