63 temp sending unit - NCRS Discussion Boards
  • jim cear
    Does anyone know of a good source for C2 temp sending units that are corretly calibrated ? Thanks
    • 43222
    Re: 63 temp sending unit
    Jim-----
    The Standard Motor Parts TS-6 sending unit has been reported to provide proper calibration. However, I have no personal experience with this unit.
    Lectric Limited has a line of reproduction temp senders that will, reportedly, provide proper calibration. Once again, I have no experience with these.
    An NOS GM #1513321 will provide proper calibration.
    • Chuck D.
      • January 30, 2007
      • 11
      I just ordered a unit for my 1964 from LIC; the sender looks correct (has the AC Delco markings, etc) and includes a short connector which will claims to calibrate the sender (you can hook up the connector at the sender or hide under the dash at the gauge). I plan to install in the next week, I will post an update. Also, I have been told to not use teflon sealant on the threads as it will minimize the ground and cause problems.
        • 43222
        Chuck-----
        You've been told correctly regarding Teflon tape or sealant. You don't want to use either. Once-upon-a-time I did and it caused me problems that took me awhile to figure out.
        The threads on the temp sender and the ones factory-tapped in the heads or intake manifold are NPTF, otherwise known as "Dryseal", and require no sealer or Teflon tape.
        • Wayne P.
          • August 31, 1975
          • 1025
          The best source is an original from an old wrecking yard.
          • John D.
            • December 1, 1979
            • 5507
            Joe, I have not had much luck with the TS-6 or the TS-8 as far as calibation goes. Course that's just me. In fact none of the over the counter temp senders I have bought have been on the money. Don't know about the repros as never tried one. John
            • John D.
              • December 1, 1979
              • 5507
              Jim, I see no one mentioned that Fred Olivia from FL is a good source of temp senders. I am sure someone here can post his email or address. I understand though that he is pretty backed up as like a lot of us he is a one man operation. John
              • Jim Cear
                Fred Olivia
                If someone has his contact onfo that would be great, I'll also search the archives.
                • Jeff S.
                  • July 31, 1984
                  • 384
                  Jim
                  I've had decent results with Wells TU-5. In this area (WI), Autozone and Farm & Fleet carry them.
                  • Kent K.
                    • December 1, 1982
                    • 1139
                    Fred Olivia Contact info
                    I have his business listed as the favorite shown below:
                    Regards, Kent Keech
                    Future Lung Cancer Survivor
                    Kent
                    NCM Founder - Member #718
