How to identify C3 RADIATOR SUPPORT - NCRS Discussion Boards
  • Michael H.
    • April 1, 2005
    • 38
    I PURCHASED A C3 RADIATOR SUPPORT NOS WITH GM STICKERS ETC. FROM REPUTABLE SOURCE - DROPPED OFF AT INSTALLATION REPAIR SHOP....DID NOT SEE STICKERS ON AFTER INSTALL??
    • 43241
    Re: How to identify C3 RADIATOR SUPPORT
    Michael-----
    Perhaps they removed the sticker after installation. That's not uncommon. I usually remove parts stickers after installation if they are very visible. Keep in mind that these are SERVICE part stickers. They were not used on PRODUCTION pieces originally installed on a car even though they are usually exactly the same or virtually the same piece originally installed on the cars. So, the sticker is a "dead giveaway" that the part has been replaced. Many folks don't like that.
    If you're concerned that they switched your NOS for a reproduction, I would doubt it, but anything is possible. If you're asking how to identify an NOS GM piece from a reproduction, it's going to be very difficult. One thing, though, is that reproductions are usually painted a much higher gloss and "thicker" black than the very semi gloss, "thin" black used on GM pieces.
    • Phil P.
      • April 1, 2006
      • 409
      NOS 1969 camaro radiator core support---i've seen these advertised on ebay with the "gm nos" part number, when you put the part number in the "system" you are actualy buying a re-pop part from a re-po house with gm re-pop certification--the camaro core support from ??? repo house is $250 ,but because some one think they are buying an NOS from 1969 or ? pays $450.00 plus---buyer be ware---there are little to no real nos parts left---jmho---phil
      • Michael H.
        • April 1, 2005
        • 38
        THANK YOU .....MIKE
