Parking Brake Shoe Spring - NCRS Discussion Boards
  • Jeff Gunn #29146
    Is it possible to remove and replace the springs behind the rear hub on the parking brake on a '74? One of the springs is damaged and I'd like to replace it but it doesn't look possible with the hub in the way. Maybe I can work it through the holes in the hub? All advice appreciated! Jeff
    Jeff's '74 Corvette Restoration Project
  • Mike Cobine
    Re: `68 body reinforced areas
    Actually, this frame reinforcement for the kick up was done in late 1968 models. My '68 convertible number 226xx has these and I doubt it was the first. Yes, original frame with the original VIN stampings, and I have had it long enough to know no one has "altered" it in restoration as it is unrestored.
