Stamp Pad Paint Removal - NCRS Discussion Boards
  • Kirk McHugh
    The stamp pad on my 67 has been painted. What is the best way to remove the paint without doing any harm to the pad surface? I see from the Tech Info Manual that there are machine marks I need to preserve. Thanks.
  • Brian M.
    • February 1, 1997
    • 1840
    Re: Stamp Pad Paint Removal
    I used a gel type paint remover and applied it with a 1" foam brush.
      • 15695
      Most spray can paint is lacquer based, so lacquer thinner will dissolve it, and an old toothbrush will usually remove the paint in the nooks and crannies.
      • Jay G.
        • August 31, 1993
        • 398
        Have used Gel-Type paint remover. Once paint is raised, remove with cotton swabs. I've put a thin coat of oil 10/30 etc to prevent any futher rust. Pad is clean. No damage to broach marks etc.
