C3 Windshield Polishing - NCRS Discussion Boards
  • Todd Robida
    I made the mistake of cleaning gunk off the windshield on my '74 with a bottle of "Fantastik" of questionable age. It left my windshield hazy and streaky. Fantastik appears to turn into varnish with age. It appears that all the tiny scratches and pits are filled in with this stuff.
    I've tried all kinds of cleaners including gasoline with no luck. I tried rubbing with a cloth by hand with toothpaste.
    Does anyone have any experience with the windshield polishing kits you can buy from Eastwood or Eckler's? I'm refering to the compound and buffing wheel that attaches to a power drill.
    Todd Robida
  • Jim T.
    • March 1, 1993
    • 5351
    Re: C3 Windshield Polishing
    GM recommends using Bon-Ami to clean a windshield. This recommendation is listed in my 96 LT4's owners manual
    • Mike G.
      • July 31, 2002
      • 709
      i use the zaino bros clear view glass polish on mine. it works well. www.zainobros.com
      • Stephen L.
        • May 31, 1984
        • 3159
        Obtain a pice of junk glass.... maybe a window on the back of your garage.
        Apply the same Fantastik cleaner to it. If you get the same results then you have a test piece. Now try solvents such as Laquer Thinner and MEK to remove the Fantasik until you find a suitable solvent.
        Now very carefully use that solvent on your windshield.......DO NOT get any of it on the paint surfaces.
        You might also try buffing with a power buffer and some light compound material.
        • Pat M.
          • April 1, 2006
          • 1578
          I've tried the Eastwood product and was pretty pleased with it. But it is fairly abrasive, and the buffing wheel is pretty hard, so it must be used with care and lots of water.
          I also tried Bon Ami and loved it. I used a very soft, cloth-like drill pad and lots of water, and the glass sparkles, with absolutely no scratches. This might work for you.
          Good luck, Patrick Moresi #45581
          • Louis T.
            • July 31, 2003
            • 282
            • Todd Robida
              Thanks To All Your Input
              Thansk to all the suggestions! With some careful precautions, I hope I can fix this.
              Todd Robida
