Vibration - NCRS Discussion Boards
Vibration
  • Albert P.
    • April 1, 2006
    • 205
    Vibration
    Getting a vibratio at and above about 3500RPM;happens in neutral,with and without clutch depressed, and in all gears;clutch imbalance? any ideas?Thanks
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Vibration
    Check U-joints
    • Chuck R.
      • April 30, 1999
      • 1434
      Re: Vibration
      Hi Garth,
      It MIGHT be a u-joint but usually if a u-joint were going south, the vibration would significantly deminish or even go away once the load is taken off the driveline (ie depressing the clutch while driving down the road)
      I would be more suspect of maybe a drive shaft issue if the vibration is consistent with the clutch engaged or depressed.
      If this "vibration" has suddenly surfaced, it could be that the shaft has thrown a balancing weight.
      Any drive line work performed on it recently?
      Chuck
      • Albert P.
        • April 1, 2006
        • 205
        Re: Vibration
        NO work done recently; are you guys referring to the drive shaft or axle u-joints? thanks
        • Chuck R.
          • April 30, 1999
          • 1434
          Re: Both
          But of the two types of shaft, I'd look over the drive shaft first and see if there is a clean area where the weight was spot welded to the shaft.
          Well, if no work has been performed to the drive line including rotors and calipers then the dive and half shafts would be even more suspect.
          Also now that I've had time to think of "other" possibilities, just maybe you have a slightly bent rear mounted rim as well.
          I had a rim once that when I mounted it back on the drum, a piece of rust fell off and wedged it'self between the rim and hub. It was off just enough to make a very anoying vibration through the car. When I popped the wheel off to check my work, the chunk of scale rust fell on the floor. Smooth a silk after that.
          If it was the clutch system, I'd have to assume that it would vibrate at ANY speed or rpm.
          Chuck
          • Albert P.
            • April 1, 2006
            • 205
            NM**Thanks for the help**NM *NM*
