This is something that I should have asked four years ago when I started my restoration but to honest I hadn't even heard of the NCRS then....wish that I had though.
Since my last post about lacquer primer I've been doing a lot of reading online about paints...what to do and what not to do and it would seem that I went at this all backwards in going from the substrate up instead of the topcoat down. Seems that topcoat choices is based on what's underneath it...right?
SO now I'm thinking that what I should be doing is trying to source the most correct 69 Cortez Silver (code 986)paint that I can whether it be lacquer or not. Then once I find this elusive paint with the right tint, shade, flakes, etc, simply use what they recommend for primers and or sealers. Is this how I should go about it?
What I still don't understand though is that a lot of the tech sheets that I have read say that "such and such" a product(mostly primers and sealers) can be used over "properly sanded OEM finishes". To me Dupont 80S lacquer primer is an OEM finish because that was what was used back then. I don't know if GM used Dupont specifically or not but they did use a lacquer primer and this 80S is/was for auto refinishing. Could someone please explain what the the difference between the two is?
Greg Linton
#45455
Oh...ummm.... what would be the proper size sandpaper grit to strip my old Dupont 80S lacquer primer off so that I can get the body ready for some "good" primer?
Greg Linton
#45455
