Normal C2 327 Oil Pressure?? - NCRS Discussion Boards
  • Bob S.
    • January 1, 2004
    • 182
    Please help me confirm this......My (aging) memory is that the normal oil pressure for a factory built C2 small block is about 40 psi @ 1500 rpm, correct? That's what I recall seeing "Car Life" magazine report back in the day....
    Bob S.
    Re: Normal C2 327 Oil Pressure??
    Unless the engine has been freshly rebuilt and is still 'tight', 40 lbs of oil pressure at 1500 RPM on a fully warmed up engine seems quite high to me. I'd expect readings in the 15-25 lbs range.
        • 15677
        It depends on the year/engine. Most are speced at 40-45 psi @ 2000, hot. Beginning late in the '63 model year mechanical lifter SBs were increased to 55-60 psi @ 2000, and this carried through on SBs through '65. SHP big blocks are the same.
        As a general rule, engines with the higher oil pressure spec have 80 psi gages, 60 for the lower spec.
        See the AMA specs for each specific year/engine.
          • 15677
          • Bob S.
            • January 1, 2004
            • 182
            Duke - Please excuse my ignorance, but what are the AMA specs and where can I find them? I'm concerned about the base 327/300 in a '67 coupe I traveled quite a distance to look at yesterday. I need a credible, spec to help with negotiations......if I decide to try to buy it.
            Thanks for your help!
            Bob S.
            • Bob S.
              • January 1, 2004
              • 182
              Bob S.
                • 15677
                "Restoration package" from GM , 800-222-1020
                Automotive Manufacturers' Assc. later called MVMA - Motor Vehicle Manufacturers' Assc.
                They are included with the GM "restoration package" that is available complementary to all vintage Corvette owners and have a lot of good technical information.
                Call GM Custormer Service at 800-222-1020. They will want your VIN.
                The '67 base 327/300 normal hot oil pressure is spec 40-45 psi @ 2000, and this level should be maintained to the redline.
                  • 15677
                  • Doug C.
                    • June 30, 2002
                    • 88
                    Re: "Restoration package" from GM , 800-222-1020
                    Speaking of the GM restoration package, are there any members in the US that would submit a Canadian members VIN to GM in order to receive the pkg and then forward it to my address in Canada? I would pay all postage required.
                    I've called the 1-800 number in the past and they would not mail to Canada. GM Canada does not seem to have a similar program. Thanks - Doug
                    • Doug C.
                      • June 30, 2002
                      • 88
                      • Mike M.
                        • September 30, 1999
                        • 710
                        Doug where are you in Canada *NM*
                        • Frank C.
                          • January 1, 1986
                          • 277
                          Doug....I'd be happy to help you. I got all my info no problem from GM. All I need is the Vin# and your address. I'll request it shipped to me and then forward it...Regards Frank
