67 coupe (435) - NCRS Discussion Boards
67 coupe (435)
  • David C.
    • December 1, 2005
    • 60
    67 coupe (435)
    A couple questions:
    1-Is there an accurate measurment on the exhaust tips -From where they come out of the rear body panel
    2-Transistor Ignition amplifier--What is the correct finish and description of the head of the bolts that attach this too the car
    3-Floor mats-Were the originals clear with a bowtie logo or what are the correct type
    4-Decals-Where on the glove box door does the tire pressure decal go and where do the decals go on the fan shroud
    Thanks in advance Dave
  • Joseph T.
    • March 1, 1986
    • 169
    Re: 67 coupe (435)
    David,
    1) No, just make sure for judging purposes the tips are centered in the rear valance exhaust bezel and clamped properly to the pipes.
    2) Mine has an sbc and a TR bolts and they are zinc plated (silver)
    3)I believe they were clear or black with bow tie symbol. You do not need them for judging .
    4)glove box decal applied inside door center above latch so you can read the instructions when door is open. I have originals that are not really centered and applied not perfectly straight. Decals on fan shroud (for a big block car) are applied inside the shroud ring , one on each section of fiberglass shroud.
    good luck.
    • Joseph T.
      • March 1, 1986
      • 169
      Re: 67 coupe (435)
      David,
      good luck.
