C2-300 HP, Balancer Bolt? - NCRS Discussion Boards
  • Donald M.
    • December 1, 1984
    • 498
    Help! Does the '67 327/300 engine use a bolt and washer to hold the balancer(tortional damper)to the crankshaft? I say it doesn't, but my mechanic friend says it does. I 'm pretty sure the balancer is just pressed on. Would the adition of a bolt/washer affect anything adversly?
    Thanx for your help.
    Don
  • Timothy B.
    • April 30, 1983
    • 5186
    Re: C2-300 HP, Balancer Bolt?
    Don,
    The 300 HP 1967 corvettes do NOT use a bolt to retain the damper. Be careful you are using the correct damper because it's press fit and tighter then the ones with bolt. Some drill and tap for a bolt when overhauling for added insurance and peace of mind. Not sure what year GM started using the bolt in all engines.
    • Chuck R.
      • April 30, 1999
      • 1434
      Tim, my late production 327/300 has the retaining bolt.
      Chuck
        • 15674
        As built by Flint, only SHP/FI 327s with the 8" damper have the crankshaft drilled and tapped for a damper retaining bolt; 250/300 HP engines were equipped with a pressed-on 6" damper with no center retaining bolt.
          • 43221
          Don-----
          GM says that all 1966-67 Corvette 300 hp small blocks had the balancer retaining bolt. These engines are supposed to use crankshaft GM PART #3889304, which has the bolt tapping. Did every 66-67 Corvette 300 hp engine have the bolt? I don't know; I've not seen every one ever built.
          For 66-67 300 hp engines WITH a crankshaft snout bolt, one should use balancer GM #3896903. This balancer has a lighter interference fit than balancers designed for use with crankshafts without the snout bolt.
          For any 57+ 283 or 327 WITHOUT a crankshaft snout bolt one MUST use balancer 3896904 (or, another balancer with equivalent interference fit).
          • Brian M.
            • February 1, 1997
            • 1839
            My Jan 67 built 300 HP did not have a bolt, but it does now.
            • Joe R.
              • March 1, 2002
              • 1356
              Hi Joe:
              My April 67 300 HP did not have the bolt, and the crank was not drilled for it (although I drilled the crank and added a bolt during some recent engine work).
              It is my impression that the 67 judges look for a no-bolt setup when they judge the 300 HP engine.
              • Joe R.
                • March 1, 2002
                • 1356
                Hi Joe:
                  I've never seen a '67 300hp engine with a balancer bolt; it's not unusual for different GM references to be contradictory, but the 327/300hp engines used a pressed-on balancer.
                    • Joe R.
                      • March 1, 2002
                      • 1356
                      Hi Brian:
                      Was your crankshaft already drilled and threaded for a bolt, or did you do that (as I did)?
                      • Joe R.
                        • March 1, 2002
                        • 1356
                        Hi Brian:
                        • Brian M.
                          • February 1, 1997
                          • 1839
                          I had it drilled & threaded.
                          • Brian M.
                            • February 1, 1997
                            • 1839
