rotella oil question and flat tappet cams??? - NCRS Discussion Boards
  • Michael F.
    • 745
    have they stopped using zinc and phosporus now, what to use in our old flat tappet motors?????????????????
    Michael
    70 Mulsanne Blue LT-1
    03 Electron Blue Z06
    • 15678
    Re: rotella oil question and flat tappet cams???
    No, do some searching on this forum to find out about the CJ-4 specification, or google API 1509 and find out for yourself directly from the source.
    Internet blogs are full of misinformation and BS.
    • Roger S.
      • May 31, 2003
      • 262
      Info from the Shell Answer Man about the wear additives in Rotella the old CI-4 verus the new CJ-4 spec's.
      He, actually a she, said
      CI-4 CJ-4
      Zinc............... 1390 ppm.......1210 ppm
      Phospherous.........1265 ppm.......1110 ppm
      About 12% lower for the new oil, but much more than the regular car SM spec oil.
      Roger
      • John D.
        • December 1, 1979
        • 5507
        The big thing is to use a good engine oil supplement and cam lube. There are at least 1000 posts on this subject in the archives. JD
          • 15678
          An oil supplement like GM EOS or "cam lube" is only for breakin, but with an OE cam and springs, it's not absolutely necessary. (GM didn't use either for new engines). After new engine breakin, CJ-4 oil is all that's necessary.
          • John D.
            • December 1, 1979
            • 5507
            What brand do you suggest Duke??? JD
              • 15678
              As you know I have no brand preference and don't recommend specific brands. The only important buying factors are API service category, viscosty, and price. I buy whatever API service category CI-4 or CJ-4 in SAE grade 15W-40 is least expensive at the time of purchase.
              • Michael F.
                • 745
                thanks duke and everyone else, glad that is cleaned up.
                Michael
                • Michael F.
                  • 745
                  Michael
                  • Doug Flaten
                    Below, I pasted a Shell response from another forum. It states the same as a prior post about a zinc content of 1200 ppm. But it also states that this applies to Shell Rotella T multigrades that carry both the CJ and SM rating. I noticed on the Shell website that not all oil grades carry both the CJ and SM rating. Since SM is showing up on some diesel oils now, it was causing confusion.
                    Doug
                    With the introduction a couple of years ago of ILSAC specification GF-4
                    and API specification SM for gasoline-only engine oils, the amount of
                    phosphorous in the oil had to be reduced to prolong the life of
                    catalytic converters. Zinc-based anti-wear compounds, which also
                    contain phosphorous, were reduced as well. These zinc compounds work
                    well to protect flat tappet engines from excessive wear, so the modern
                    gasoline-only engine oils are not as effective in this regard as they
                    once were.
                    Diesel engine oils don't suffer from the same requirements to protect
                    catalytic converters, so the amount of zinc-based anti-wear additives
                    remained high. Products like Shell Rotella T Oils, which also carry API
                    S-series licenses for gasoline engines, have found favor for flat tappet
                    engines.
                    There has been a recent change to the API specification required for
                    oils used in 2007 big rig diesel engines to reduce particulate
                    emissions, API CJ-4, and that oil does also carry an API SM rating. As
                    a result, the zinc content in Shell Rotella T Multigrade Oils has been
                    reduced slightly from about 1400 ppm to about 1200 ppm. Even at these
                    slightly decreased levels, Shell Rotella T Multigrade Oils still have at
                    least 50% more of these anti-wear additives as most current
                    gasoline-only engine oils. These levels of zinc have historically
                    offered good protection in flat tappet applications.
                    Thank you for your interest in Shell Rotella Products!
                    Edward Calcote
                    Staff Chemist, Shell Lubricants US Technical Information Center
                    For over 40 years, Shell Rotella® has delivered lubes, greases, and oils to provide unrivaled protection and performance for heavy duty vehicles and equipment.
                    • Doug Flaten
                      Doug
                      once were.
                      engines.
                      Edward Calcote
                        • 15678
                        I also explained this in previous postings. The first listed API category is the PRIMARY application, and any oil that carries SM as the FIRST (and primary) category CANNOT carry ANY other service category.
                        The phosphorous limitation (which places a limit on the ZDDP anti-wear additive)of .08% (800 ppm) for SM oils ONLY applies to those with a winter SAE viscosity grade of 10W or below, so theoretically a 20W-50 SM can have greater than .08% P, but there is no guarantee that this is the case.
                        The CJ-4 phosophorous limitation is 0.12%, which is the bottom end of the typical concentration range for previous C-category oils.
                        This is all spelled out in the API 1509 Engine Oil licensing and Certification System document that you can locate (and download) off the Internet after a quick Google search.
                        Thus, a 15W-40 CJ-4 can also carry SM as a secondary rating because the 15W winter rating exempts it from the .08% phosphorous limitation in the SM specification.
                        The bottom line is that a 15W-40 CJ-4 is the best commonly available motor oil for vintage engines in typical service, but if you consistently do cold starts below 15 degrees F, use the more expensive 5W-40 CJ-4, which shouldn't carry a SM rating because the winter viscosity rating is below 10W.
                        The 5W-40s are made primarily from Group II and III base stocks, which have a higher viscosity index than Group I that is the primarly base stock used in 15W-40 along with a little Group II or III to meet the tough anti-oxidation requirements. The 5W-40 can also probably be referred to as "synthetic", but the marketers appear to avoid saying this since "synthetic" is now widely understood as just marketing hype, and commercial operators who are the primary customers for CJ-4 oils prefer facts to hype.
                          • 15678
