60 frame serial number location and size? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 939
    Looking for serial number on my 60 vette frame. There is some rust surface rust where I think it should be. left side on the top side of the frame, below drivers left leg/knee. Is it the complete serial number or just the last 5 digits? What size are the charactors, 1/4, 5/16. 3/8? Could I spray something on to bring out the charactors?
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Bill, I'd say top left, under 'yo butt...
    ...maybe double stamped...???
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11323
      Re: 60 frame serial number location and size?
      Bill, It's about at the front of the seat bottom, probably around the back of your knee towards the calf of your leg. It is the complete serial number, sometimes stamped twice. I found mine(on my 59) using sandpaper & scotch-brite and then carefully looking with a mirror long ago. I was due to check it again so see pics below. Nice flat mirror(stole my wife's compact), and double stick taped to the floor. Characters are about 3/8 inch high. The end of mine is right next to the plastic floor plug. Check around there. Overall length is about 3 1/2" long. Mine is pretty close to the edge of the frame top as you can see.
      http://tinyurl.com/3ao66x
      http://tinyurl.com/32k3nu
      Rich
      • John O.
        • May 31, 1998
        • 480
        Hi Bill
        I read here before that once you clean the rust away real good,use an air hose and blow the dust away carefully, then take a piece of white chalk and rub it over the whole number area. Wipe over that area so that the chalk is only in the numbers. Then it makes it easier to see with a mirror.
        Good luck...John
        • William B.
          • April 30, 1975
          • 939
          Thanks everyone, I'll look harder.
          • Dennis A.
            • April 30, 1999
            • 1010
            Bill...
            If it will help, on the driver side main frame rail is a 1/2 inch dia. hole drilled on the vertical side and located 2 1/4 inches from the top of the rail, directly below the middle of the drivers side door. The serial number is normally stamped on top of the rail, directly above the 1/2 inch hole. The number is sometimes stamped twice and I have found them also under the ribbed rubber cushion cemented on top the rail. The numbers may be very faint, so the caulk method is a good one.
