Mid 69 timing mark - NCRS Discussion Boards
Mid 69 timing mark
  • AC
    Mid 69 timing mark
    I have a mid year 69 and it has some early 69 things, and some late 69 things. My motor has been rebuilt (before I bought it), and I was wondering what timing mark I am supposed to have. Right now it has a 10 degree timing mark on the torsional damper (which I know is not the original damper). When I tried to time it, it was way off...(the timing mark and pointer are obviously not the same degree marking). Does anyone know when Chevy switched from 2 degree to 10? I am either gonna buy a new damper or timing pointer, but I don't know which one is wrong. Thanks
    AC
  • Redondo Duke NCRS #22045
    Re: Mid 69 timing mark
    My '63 has a timing tab welded to the timing chain cover. Beginning about 1969 Chevrolet used a bolted on timing tap that was secured with the timing cover bolts, and I think the index mark on the balancer changed so you have to have the correct balancer for the type of timing tab.
    404 Page. We could not find the page you were trying to locate.
