body lift - NCRS Discussion Boards
body lift
  • Tom K.
    • August 31, 1989
    • 28
    body lift
    would a hydrolic cherry picker with a 1500lb capacity be sufficient to lift the body off a 65 roadster? thanks for your help, i love this site!!!!!!!!
  • Sander B.
    • March 1, 2005
    • 499
    Re: body lift
    1500lb is strong enough to lift a boddy
    you can even lift the body with 2 or 4 people
    its not so heavy
    good luck Sander,
    • Tom K.
      • August 31, 1989
      • 28
      Re: body lift
      thanks sander,i'm also going to use it to pull the engine so it will have double duty
      • Tom L.
        • May 7, 2007
        • 438
        Re: body lift
        I recently pulled the body from my 1970 with an engine hoist. No problem at all. However, you can't roll the chassis out from under the body b/c the hoist is in the way. I picked up a cheap set of dollies and rolled the chassis out from the side of the body.
