1991 stalling - NCRS Discussion Boards
1991 stalling
  • Richard Cooper
    1991 stalling
    I have a 1991 corvette and was hoping someone could help with a problem. What it is doing is after sitting over night when I start it and drive it runs great, but after shutting it off say for 1/2 an hour it idles differently and when I get on it it stalls out. The computer said the map sensor was bad and I replaced that and erased trouble codes but that didn't help. It is not throwing any new codes. I took it in and had a scanner put on it and it showed no codes as well. Thanks in advance Rich
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 1991 stalling
    Have you checked the injectors ??? My guess is you'll find a couple of weak ones, if not all 8.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • john daly
      Re: 1991 stalling
      Richard,
      A fuel pressure reading while the car is acting up would help with the problem.
      I had the same problem onceand it ended up being the Idle air control valve.
      good luck
      john
      • Jim T.
        • March 1, 1993
        • 5351
        Re: 1991 stalling
        John did you clean the idle air control valve or replace it?
        • George D.
          • August 31, 2000
          • 225
          Re: 1991 stalling
          I would agree with checking the injectors. They can be weak and not set any codes. I recently changed all 8 in my 90 and it made a huge differenct in performance.
          • john daly
            Re: 1991 stalling
            Jim,
            I replaced it, but I cleaned the passage out with carb cleaner first.
            john
