C2 carb fuel inlet - NCRS Discussion Boards
C2 carb fuel inlet
  • Brian K.
    • September 19, 2007
    • 174
    C2 carb fuel inlet
    I have a banjo inlet on a universal Holley 650 single feed. I want to convert it to accept the correct fuel line & brass filter. Does anyone know what & where to get the correct part for that? The carb to pump line is 5/16 I think?
    Brian
    66 Coupe
    66 Convertible
    2022 2LT Coupe
    67 Chevelle SS396
    67 XLCH HD Sportster
  • Brian K.
    • 174
    Re: C2 carb fuel inlet
    Oops! Its a 327/300
    66 Coupe
    66 Convertible
    2022 2LT Coupe
    67 Chevelle SS396
    • Wayne K.
      • December 1, 1999
      • 1030
      Brian,
      I think you are going to have to find a correct complete bowl as the inlet housing for the filter is part of the bowl itself, not something you can attach to the existing bowl on the carb that you have now.
      • Gerard F.
        • June 30, 2004
        • 3806
        Brian,
        As Wayne said, the inlet is part of the front fuel bowl. You would have to find fuel bowl assembly for a 66 3367 or other 65/66 holley with the same inlet configuration. Be aware that there are other differences in the fuel bowls as to venting and float adjustment, and crossover pipe, so there is no guarantee that the fuel bowl will fit on your generic holley.
        Would suggest that you look for a Holley 3367 which is the correct one for your 66 S/B w/o AIR, 3605 with AIR.
        Jerry Fuccillo
        #42179
        Jerry Fuccillo
        • Brian K.
          • 174
          Thank you all for the help!
          Brian
          66 Coupe
          66 Convertible
          2022 2LT Coupe
          67 Chevelle SS396
