'63 radio - NCRS Discussion Boards
'63 radio
  • Steve Steffensen
    '63 radio
    My on going 8 year project '63 is finally getting a correct radio. My problem is that the wiring in the dash from the harness has been cut - there is no connector to plug into the radio. #1 Where can I get one? #2 where do each of the, what appears to be 3 wires go (or come from, depending on your prospective) that plug into the radio and what colors are they? (i.e. top is red and is hot, 2 is black and ground, 3 is yellow and something). I would like to check the radio out before sending it out and not have to install it. I have the equipment to hook it up, but need to know the wiring so I do not cause any damage. Thanks
  • Kenneth S.
    • July 31, 1981
    • 302
    Re: '63 radio
    The three wires going to the radio should be Brn/Wht for +12V, Blk/Wht for Ground and Gray for the Dial Light. You should be able to get just a connector from the folks who make wiring harnesses, Lectric Limited or M. Parker Autoworks.
    • Bill Clupper
      Re: '63 radio
      In addition, correct hookup should be available in the '63 service manual, or the assy manual. Another source for connectors is any junkyard with a '62-64 Chevrolet Pass car in residence.
