Wheel balance weights - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    Anyone know what to clean old lead wheel weights with? Thanks in advance.
  • Gary B.
    • February 1, 1997
    • 7024
    I've successfully used a toothbrush, baking soda mixed in water or 0000 steel wool.
    Gary
    • Joe R.
      • March 1, 2002
      • 1356
      Re: Wheel balance weights
      I experimented with several different methods including bead blasting at low pressure, chemical dips, and scrubbing with mild abrasives. In the end, the method that I thought gave the best result was to clean them with a SOFT brass wire brush.
      The brush I used looked sort of like a tooth brush. These can be found at hardware stores and car show flea markets, although some are softer than others.
      The resulting finish on the lead was just a bit too bright, but the finish oxidizes slightly within a few weeks and dulls down a bit.
