C2 - Hardtop & Soft Top Restore Advice - NCRS Discussion Boards
  • Joel T.
    • April 30, 2005
    • 765
    Guys,
    I'm still working on the 1965 Vert.. and am up to the point where I need to restore the soft top and the hardtop.
    On the soft top, I have all the parts, including a replacement header bow (the original had bondo to cover the rust through spots). What I need to find is someone to powdercoat the mechanism before I put it back together. Can someone recommend a trusted place to get this done in the general New Jersey area?? I would prefer to drop it off and pick it up as opposed to shipping it.
    On the hardtop, I have it stripped, cleaned and painted and am looking for someone to do all the seals, rear glass, etc. Same question here, can someone recommend a place to get this done, local to NJ.
    Thanks Much!!
    Joel
  • Harry Sadlock
    Re: C2 - Hardtop & Soft Top Restore Advice
    Joel, on the hardtop. You can probably do the work yourself as it is not that difficult. But if you must send it out look at www.autoentec.com.
    If yo decide to do it yourself look at that site for the parts you need. They will be pricey no matter where you look.
    Also, there is an AIM just for the hardtop to assist with assembly
    Harry
    • Joel T.
      • April 30, 2005
      • 765
      Harry,
      Thanks! I've been looking at the price of parts and see where it will be pretty expensive to do..
      Joel
