63 speedometer error - NCRS Discussion Boards
  • chris meyer
    My 63 coupe speedometer appears to read about 10 mph too fast when I drive down the road. When I stop, the needle doesn't fall to zero mph, but stops at about 5 mph. When I put the car in reverse and move backward slighty, the needle falls to zero mph. I have a friend who is more technically savvy than I change speedometer gears with no result. The car has a 410 rear end. Can anyone tell me what I need to do to fix this problem? I tried checking the achives without much success.
    Chris Meyer #32100
  • William V.
    • December 1, 1988
    • 399
    Re: 63 speedometer error
    Chris
    Is the error constant? (10mph error at all speeds) or does the error get larger the faster you go?
    If the error is is constant that I would suspect the speedometer. If the error increases with speed I would spect a speed gear ratio tire size type of trouble.
    I suggest checking the error at speeds of 20,30,40,50 ect to see if the error is constant or increasing.
    Good Luck
    BV
    • chris meyer
      Bill,
      Thanks for your response. I'll check the extent of the speedometer error at your recommended speeds.
      Chris
        • 43221
        chris-----
        From what you describe, my guess would be that your problem is with the instrument, itself, rather than anything "upstream" of it. But, the other things are worth checking first.
        • Bob R.
          • June 30, 2002
          • 1595
          I had the gages in my 63 restored last year and I was supprised to see it had an effect on the speedometer. Several years ago I replaced the gear in my transmission so the speedometer would agree with my actual speed. Now my speedo now runs about 5 mph slow. I guess I need to replace the original gear I took out. The restored gages run nice and smooth as they probably did when new.
