67 stamp pad ? - NCRS Discussion Boards
67 stamp pad ?
  • Tom S.
    • March 1, 2004
    • 1087
    67 stamp pad ?
    I am looking at a 67 327/350 with manual transmission and a/c. The stamp pad reads v0329ht. My book says that is correct less the a/c. Is this possible that someone did not stamp it correctly or was the a/c not added on some cars?
    Thank you in advance. Tom
    • 43221
    Re: 67 stamp pad ?
    Tom----
    Does the car have originally-installed power steering? In any event, and regardless of what references may say, I don't see any reason why an "HT" coded (and configured) engine could not have been used for either C-60 or non C-60 1967 L-79 applications.
    • Tom S.
      • March 1, 2004
      • 1087
      Re: 67 stamp pad ?
      Joe
      the car does have p/s so I would think that it should be stamped HP but I am not sure. It was nice meeting you by the way. It is always nice to put a face with a name. Thanks Tom
      • Tom S.
        • March 1, 2004
        • 1087
        Re: 67 stamp pad ?
        By the way the car does have the correct block # 3892657 in it.Tom
        • Jimmy B.
          • July 31, 1980
          • 584
          Re: 67 stamp pad ?
          HT is the correct engine code for 350 hp w/AC and no power steering.
          My car has this and I have the protecto plate and the tank sticker
          • Chris E.
            • November 3, 2006
            • 1326
            Re: 67 stamp pad ?
            Uh, no, HT is correct for a 327/350, 4 speed, no air, no PS.
            If the air is original to the car, then the pad should read HP or KH.
            Source: 53-67 NCRS pocket guide.
            Chris Enstrom
            2011 Z06, red/red
