57 scortched paint on hood - NCRS Discussion Boards
  • paul bowers
    i have same paint on hood for 30 yrs. last yr. i had engine rebuilt with corect 0ne four barrel carb. correct size air filter bu now my paint on hood is all scorthed and bubbled
    what is happening and what can i do it seems to be spreading could i put some sort of material over air cleaner when i drive or some sort of material glued under side of hood thanks need help
    paul
  • Verle R.
    • March 1, 1989
    • 1163
    Re: 57 scortched paint on hood
    Paul,
    Are you referring to the paint on the bottom or top of the hood?
    In either case, just changing the carburetor and air cleaner should not affect the paint. Did you drive the car with no air cleaner? Did it pop back through the carburetor?
    Verle
    • Roy B.
      • February 1, 1975
      • 7044
      Seen that happen many times having the hood open and the sun reflecting on the chrome air cleaner burning (heat) cause the same thing.
      • Kevin M.
        • November 1, 2000
        • 1271
        Damn Roy I was a typing the same thing. LOL Wasn't sure if the AC was chrome.
        • paul bowers
          this the paint on the outside of the hood
          it is coming fron engine while car is running/driving and it is all blisteredl plus when I feel "outside" of hood after driving, outside of hood very hot
          thanks
          • paul bowers
            never did that, this has happen after changing to correct carb./correct air cleaner, and engine rebuild out side of hood feels very hot to touch the paint is now blistered
            and ruined could i put some sort of material on top of cleaner or glue to underside of hood over carb. area, thou i should not have to do what could be reaon
            thanks Verle
            paul
            • Phil P.
              • April 1, 2006
              • 409
              sounds like the engine is very lean *NM*
              • Roy B.
                • February 1, 1975
                • 7044
                That's a new on me (getting hot) only thing I can think of is the choke vacuum pulling to much hot AIR making everything hot , you know the Corvette Carb base is Corvette only? Car is thicker! The heat cross over would get the intake hotter if the heat riser is stuck closed or the manifold shield fell off. Let see what others say varrrry interesting????
                  Paul -
                  Is it new paint? Is your heat riser valve stuck closed?
                  • paul bowers
                    john,
                    the paint is 30yrs. old and "looked" great
                    i think riser is open i can feel exhaust comming out left side when i place my hand by tail exhaust but i will check at engine area also can;t get my idle to come down by trying to un screw small set screw on carb. leakagew
                    thanks
                    • Richard P.
                      • July 31, 1995
                      • 57
                      Could it be that you have an exhaust leak? I've melted a battery cable with a leak at the donut. Just a thought
