C2 Engine Wire Harness - 1966 - NCRS Discussion Boards
  • Robert T.
    • May 31, 1993
    • 346
    Can someone please tell me what direction the pops rivets are pulled from on the two wire harness retaining clips along the hood channel near the firewall. Looking at UPC 12 in the AIM, and the faded directions I got from Paragon, it looks like one is pulled from one direction and one from the other. That is, the LS is pulled into the engine compartment, and the RS is pulled toward the outside of the car. Is that really correct? Thanks for any help offered.
    Bob
  • William C.
    • May 31, 1975
    • 6037
    (Message Deleted by Poster)
    Bill Clupper #618
    • William C.
      • May 31, 1975
      • 6037
      Re: C2 Engine Wire Harness - 1966
      What page of the UPC 12 are you referencing?
      Bill Clupper #618
      • Robert T.
        • May 31, 1993
        • 346
        I was looking at UPC 12 Ref A9 (p218 in my copy) and UPC 12 Ref A11 (p220).
        The RS rivet direction is shown on p218, and the LS is shown on p 220.
        Bob
        • William C.
          • May 31, 1975
          • 6037
          ignore the picture, both sides are pulled from the engine compartment side. Any other option leaves the rivet end gouging the hood frame.
          Bill Clupper #618
          • Robert T.
            • May 31, 1993
            • 346
            Thanks Bill,
            That's what I would have thought. Thanks for taking the time to respond.
            Pieces of my LS surround were replaced before I got the car so I couldn't check it. I had to redo the RS, but come to think of it,the RS was original and I still have that piece. Maybe I'll go out to the shed and see if the original rivet is still on the RS.
            Thanks again for the help.
            Bob
            • Wayne W.
              • April 30, 1982
              • 3605
              Now the question is which kind of rivet will he use.
              • Robert T.
                • May 31, 1993
                • 346
                Ahhh, good question. If I can figure out how to post a picture I will, but for now I'll have to rely on this description to convey the installation. Like I said before, unfortunitly my LS was replaced so I can't tell what type of rivet was used nor what direction it was installed. I still have the original RS though. It has a Rosette rivet pulled toward the outside away fron the engine compartment. It does protrude into the hood "gutter", but not enough to interfere with the hood.
                Bob
                • Wayne W.
                  • April 30, 1982
                  • 3605
                  Interesting, never seen one put in that way, but many 66s had rosettes, some had solid, most had regular pops.
                  • Robert T.
                    • May 31, 1993
                    • 346
                    Thanks for the info, Wayne. Just for grins I'll try to post the picture.
                    Bob
                    • Robert T.
                      • May 31, 1993
                      • 346
                      Hello Wayne,
                      Here are a couple of pictures of that weird rivet. Hope this works. Thanks.
                      Bob
                      Daftar dan mainkan slot gacor dengan RTP tertinggi hari ini. VIPTOTO, situs terpercaya untuk cuan besar dari slot online!
