1959 coil balister - NCRS Discussion Boards
1959 coil balister
  • rick hendel
    1959 coil balister
    I have a 1959 that would not start. I traced the problem to a cracked coil balister. I put a new one in and it also failed,the second one I put in seems to work and the car started right up. I only ran it for two or three minutes and noticed the ceramic balister really got hot so I turned off the engine so I would not fry the second one . My question is should they get real hot to the touch. What not what should I be looking for . Thanks Rick
  • Mike M.
    • May 31, 1974
    • 8388
    Re: 1959 coil balister
    when functioning properly, a ballast resistor will get hot enough to be real hot to the touch. mike
    • John D.
      • December 1, 1979
      • 5507
      Rick, Look at the back side of a ballist resistor or resistor block as some call it. Notice the wiring? Sorta like a toaster in your kitchen so naturally the thing gets very hot. It controls the voltage to the coil. A mismatch of the coil and BR can result in a fried ignition system for sure. TI's don't have this part. That questions comes up about once a week. Look on the archives as there are a ton of posts on BR's. John
