1972 gas tank - NCRS Discussion Boards
1972 gas tank
  • Chuck Buchanan
    1972 gas tank
    My gas tank slipped or tilted backward. The filler neck is toward the rear. When I adjust the tank to the proper position it moves back when I tighten the straps. Any thoughts? Thanks, Chuck
  • Mark J.
    • March 1, 1996
    • 254
    Re: 1972 gas tank
    Chuck,
    It's difficult to speculate on your problem without seeing it. Normally, if the tank is resting straight on the rear frame crossmember and the tank support, the straps will put pressure straight down on the tank to hold it in place. Did you buy the car like this? Does the car have frame damage and therefore allowing the tank to slip off the rear crossmember?
    Mark
    • Chuck Buchanan
      Re: 1972 gas tank
      Mark, The tank was ok when I bought it. It did have a new tank on though. GM part no. so that seems to be right. I was thinking maybe a spacer. Though the GM assembly manual shows there is none. Thanks for the help, I'll keep trying.
      Chuck
