What could I expect to see as a point deduction for a later "service replacement" holley carburetor? The carb has correct part and list numbers as well as metering blocks, etc. and would be correct otherwise. Thanks, Steve
Point deduction for incorrect C2 carburetor date?
Using the 5-factor system...
Steve,
I've never judged mechanical before, but I'll take a stab at an answer. On C2s, there are 40 points for originality for the carburetor. Based on the 5-factor system (completeness, finish, date, configuration, installation), date alone would count for 8 points. So if all other aspects are correct and only the date is wrong, I'd say the deduct would be 8 points.
Gary- Top
Re: Point deduction for incorrect C2 carburetor da
I can't speak to C2 score sheets (but you can download them from a link at the top of this page), but some score sheets have a specific line item for the carburetor date. It may be different than the 20% Gary mentioned.Terry- Top
adendum
Well the link for the score sheets moved from the top of this page -- trust me it used to be there.
Now here:
NCRS score sheetsTerry- Top
