327 id - NCRS Discussion Boards
327 id
  • Frank D.
    • November 1, 2005
    • 19
    327 id
    I have a small journal 327 I pulled from a '66 Impala a few years ago. I was able to drive it and it ran great. It has flat tops and a GM hydraulic cam, standard bore/crank, GM bearings etc. I could use some help identifying it. Numbers as follows; cast# 3858174 dated L225 pad FOII9HCH (no vin#)
    heads 461's dated L35 & L165 cast iron intake# 3844459
    Why no vin#? Could this be a replacement engine prior to the CE designation? And from/for what? Thanks in advance Frank #44725
  • Verne Frantz
    Re: 327 id
    Frank,
    IT looks like you have the original engine from that '66 Impala. (not a CE replacement) Casting number is 327 (used '64-'67) Suffix code is 327/275hp with P/G trans. Should have a hydraulic cam, good heads and a Q-Jet. Cast on Dec 22nd '65 & assembled on Jan 19th '66. No VIN derivitives were used on "non-hipo" engines that year in Pass cars, that I know of. Sounds like it has it's orig. heads but the intake may have been changed. (check the date)
    Verne
    • Frank D.
      • November 1, 2005
      • 19
      Re: 327 id
      Verne
      Thanks very much for your response. You have answered my questions. I am surprised to find a nice matching block & heads unmolested. The car was totally crushed by a huge oak tree & the interior filled up with water during the 2004 hurricanes. Thanks again Frank #44725
      • Dan A.
        • May 31, 1974
        • 1074
        • Frank D.
          • November 1, 2005
          • 19
          Re: 327 id
          Dan
          Thanks for your reply. The engine did have a small holley four barrell and I still have it. I could not find the three character engine code and thats what made me wonder. Thanks again Frank #44725
          • Dan A.
            • May 31, 1974
            • 1074
            Re: 327 id
            The Holleys on a 275hp 327 passenger car with an HCH suffix were List 3230.
            Your 3844459 intake was used on 300hp 327's in 1963-4-5 with a Carter AFB for all lines of Chevys.
            • Frank D.
              • November 1, 2005
              • 19
              Re: 327 id
              Dan
              I have three cast iron intakes and I think I read the numbers off the wrong one. I will check the numbers on the Holley. What I am really interested in is the block and heads, will freshen them up and keep 'em around. Thanks Frank #44725
