C1 dash wiring harness replacement - NCRS Discussion Boards
  • Matt F.
    • June 30, 2002
    • 79
    Having continuing problems with my car ('60) dying as a result of poor connections where the ignition wires terminate at the ignition switch. I'm planning to go ahead and replace the dash wiring harness, and would appreciate any pre-work advice, pitfalls to avoid, etc.
    thanks
    -Matt
  • Bob Simard
    The ignition is on its own harness. Replacing the main harness will not solve ignition harness problems. However, it may solve a host of other problems.
    • Matt F.
      • June 30, 2002
      • 79
      Re: C1 dash wiring harness
      Sorry, I meant the engine harness. I believe Lectric Limited sells one that goes to the ignition switch...
      • Michael L.
        • July 31, 2005
        • 562
        Matt, leave the old wiring in until you get the new harness, then replace wires one at a time to get proper wiring. Helps to have a diagram as well, LL sells them. Or you could consider one the Doc sells in color...
        • Christopher R.
          • March 31, 1975
          • 1599
          Re: C1 dash wiring harness replacement
          Take the steering wheel off. Take the driver's or both of the seats out. Will give you lots more room.
          • paul bowers
            matt, i replaced mine several yrs. ago like others said do one wire at a time
            i also ordered the large print wiring diagram from them it helped alot i also
            marked each new wire end of the new harness with masking tape with a number corsponding to a number on print sheet making up a number list.i think i had to take out my grill to do rt/lft horns
