Alt Pulley ID Challenge.... - NCRS Discussion Boards
  • Jim V.
    • November 1, 1991
    • 587
    Ok...pictured below are three C2 SB altenators with three different pulleys. Can you ID from left to right? I know one application for leftmost is 65 300hp no A/C. Your thoughts?
  • Phil P.
    • April 1, 2006
    • 409
    Re: Alt Pulley ID Challenge....
    i'll give it a go
    far left no a/c but has power steering
    next a/c and power steering
    far right looks like pass car
    • Wayne M.
      • March 1, 1980
      • 6414
      My Guess (from a '65 perspective)
      If you gave the outer pulley diameters it would help. BTW, fans for the 2 on the left have the appropriate 1965-era vane rib markings.
      Left -- tend to agree with you IF the pulley is 2_13/16" dia., would be #3741241 (ie. for '65 base and L75 engines, no air). I'm not sure about the thick back offset -- looks a bit much but I don't have a low-horse car to compare.
      Middle is easier. It's the 3_5/8" #3871242 for F.I., L79 and L76 w/o C60; and L78 w/P.S. (replaced by #3829193 for the 396, which I think is identical except for shaft tightness)
      On the right: looks like a later ('66+ fan) design) ? Pulley is separate and appears around 2_5/8" dia which would make it suitable for low horse Corvette engines w/C60, or a multitude of GM uses, depending on the vehicle.
      • Timothy B.
        • April 30, 1983
        • 5186
        Re: My Guess (from a '65 perspective)
        Agree with Wayne except I think the alternator on right is 1963 passenger car. I know the fan is 63 because of the unique half moon cut out on each blade. The pulley may be for AC but I think there is supposed to be a baffle between the fan and pulley.
        • Jim V.
          • November 1, 1991
          • 587
          yup....leftmost has 2 13/16 dia
          Middle is approximately 3 5/8 (3.669)
          Right is approx 2 5/8 (2.608)
          • Jim V.
            • November 1, 1991
            • 587
            Phil...I tend to agree with Wayne on left and middle. I know left is from L75 no p/s no a/c. Note certain on middle and right.
            • James W.
              • December 1, 1990
              • 2658
              So... would the one on the left be correct of a 1964 Corvette with 327/300 and without PS also?
              James West
              • Jim V.
                • November 1, 1991
                • 587
                3871241 pulley is specified for both 64 and 65. Wayne meant 3871241 not 3741241...
