67 Convertible Rear Deck Lid - Drains? - NCRS Discussion Boards
  • Kirk McHugh
    I've noticed some slots in the track around the rear convertible deck lid of my 67. Are these water drains, and if so did they once have drain tubes to exit the rear compartment? Thanks.
  • Geoff C.
    • May 31, 1979
    • 1613
    Yes... Nope never. *NM*
    • Harry Sadlock
      Re: 67 Convertible Rear Deck Lid - Drains?
      Kirk, I'm sure it's just like my 63. Water drains into the fiberglass track that runs under the rear clip, just in front of the deck hinges. Each hinge has two bolts into the track. Next the water runs to either side and exits the car just above each rear tire.
      I wrote a Restorer article about Deck Lid Hinge Repair. The article is in Volume 32, Number 4, Spring 2006. It shows the damage that occurs when that drainage track is not kept clear and the water is allowed to sit in the car.
      Harry
      • Kirk McHugh
        Having a hard time visualizing what it is you're saying, so I will have to check it out again because I'm not sure what to check to clean out. Thanks.
          Kirk -
          All convertibles have drain slots about 1" long in the bottom of the deck lid gutter section about 1" inboard of the hinge arms on each side; they drain outboard through holes in the vertical wall of the underbody into the rear wheel opening. See the assembly manual, UPC 1 Bolt/Weld, Sheet B9, View "A". Run a piece of stiff wire through the slot to make sure the drain passage is clear into the wheel opening.
          • Harry Sadlock
            Kirk, do you have the Restorer article I referenced? If not, I can scan it and email to you.
            Harry
            • Kirk McHugh
              That makes a little more sense as I have been detailing my wheel wells recents and saw slots located in the tops. I just wasn't sure how the water got from the slots in deck lid rim to the slot in the wheel well. I assumed there was some sort of tube needed. I will definitely check it out tonight. Thanks.
              • Kirk McHugh
                I do not. That would be great thanks.
                Kirk
                • Harry Sadlock
                  Kirk, select the email option and send me your email address.
                  Harry
